Home > Technical > Weird Mamba antics this morning... :(
Page 2 of 3 <123>
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
under the seatbox, they are normally yellow. mine has two yellow ones, then a black one, the black one can be left as it is the fuel pump relay i think Rolling Eyes
Post #379194 15th Dec 2014 2:32pm
Venomator
Brilliant, thanks Will... Bow down  Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #379195 15th Dec 2014 2:33pm
110MGD
2001 Defender 90 Td5 CSW Epsom Green
mk1collector wrote:
That's odd! Mine (td5) for the first time this morning when I turned the ignition to let the glow plugs warm, the Rev counter went up to 50 for a second then went back down Confused After that it was fine and ran fine, but I've never had anything like that happen before.
Ray
I have had this before. Nothing has happened 2,000 miles later, nor has it repeated this. Rolling Eyes 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #379312 15th Dec 2014 9:07pm
Venomator
Thank you, thank you...
Firstly, a big thank you to everyone who chipped in, especially relatively swiftly, with suggestions, remedies and other hints and tips in response to my problems yesterday, THANK YOU... Bow down
I have now worked out how to check the Trouble Codes on my UltraGuage (first time for everything!)... Embarassed
The only Trouble Code showing up is U0001 - which, checking historic posts, appears to be some kind of comms error, or even, according to @Lorryman100 may be something to do with the OBDII connector or possibly the UltraGuage itself?
There are no other Trouble Codes, or Pending Codes... Very Happy
Mamba is currently running sweetly, having apparently sorted the issue all by itself, so I will try and check the suggestions everyone has kindly contributed at the weekend (a good excuse to avoid the festive shopping trip!)... Whistle
Again, thank you everyone, what a brilliant, knowledgeable and helpful community this really is... Thumbs Up
 Rog... Mr. Green
The GREEN One...
Post #379379 16th Dec 2014 9:45am
Caterham
DaveH - reference you comment about the ecu earth....where's this located and would it be easy to put an additional earth (belt n braces so to speak?)
many thanks.
Post #429887 10th Jun 2015 7:03am
K9F
Just fit an extra one Caterham. You're going to anyway. It has six main earths feeding to three different earth points, the primary one being the 'case' of the ECU itself. You go figure where to connect it and how to find it. It should be easy to spot. If you can't please leave well alone!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429889 10th Jun 2015 7:20am
Caterham
thanks Mal.
will be finding the time to 'fiddle' the weekend. couldn't believe my eyes last night with dash board lighting up like a Christmas tree AFTER fixing the earth on the battery. - Was UTTERLY unbelievable !
Post #429892 10th Jun 2015 7:30am
K9F
Did you go through 'due process' for disconnecting the battery or just 'crack on' and did it?
With regards to your ultragauge (if it is an ultragauge) it has an internal fuse in the OBD connector that cannot be replaced apparently.
http://ultra-gauge.com/ultragauge/support/...manual.pdf If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429893 10th Jun 2015 7:39am
Caterham
erm.... Embarassed
processes....what do you mean exactly? was only the 'neg' didn't touch the red for danger thing.
kinda thought...... (thinking about it I didn't do much thinking).
Post #429895 10th Jun 2015 7:42am
K9F
Thud Thud Makes no difference you're still isolating the battery from the vehicle. Have a look in the manual about switching ignition to position 2 turning off then disconnecting within 15 seconds. Irrespective of what they may be for 'processes' are there for a reason usually. Did your alarm sound? If not you may have an issue with it that needs extensive investigation?
Christmas Tree lights after messing with the battery as you did doesn't seem that surprising to me, you should have removed the positive as well to prevent 'flashing' the electronics each time you reconnected the negative, which I would wager would have been numerous times.
Whistle
http://www.defender2.net/forum/topic3168.h...disconnect If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429897 10th Jun 2015 7:45am
Caterham
Confused
I took the earth off more than once last night no alarm....all 'seems' fine.
just gone outside expecting to have to press the down button on the ultragauge after having a look through the instructions (thank you Mal) and even that is now working. not been for a drive so can't say for sure if the dash is going to light and dance when I go for a drive but starting the engine up deemed fine???
??? and a few more ????
- Mal if I'm not mistaken you're deliberately trying to worry me with procedures right?
Thumbs Up
Post #429903 10th Jun 2015 8:00am
K9F
If I don't follow the procedure my alarm sounds! I also have the added bonus of my tracker company phoning me at the same time if I forget to notify them first! Embarassed Doesn't yours? Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429916 10th Jun 2015 8:28am
Caterham
....... Neutral
that'll be a
NO and NO. Sad
something else to check out - thanks. - as in your alarm makes your horns sound or you have the battery backed siren?
upon reflection I wonder if the lead to the ultragauge was slightly squeezed in between some trim/carpet causing interference? seems very strange that it started after the battery disconnect tho? will monitor?
Post #429918 10th Jun 2015 8:32am
munch90
disconnecting the battery will/should if fitted make just the back up siren sound , no horns
Post #430044 10th Jun 2015 6:31pm
Not everyone's Defender has a BBUS.
Mine reacts the same as Veno's.
I have a Skytag too, supposed to email / text when power cut I.e. Battery disconnected.
Did that last week when I took the battery out.
No text or email at all. Confused
Post #430047 10th Jun 2015 6:43pm
Page 2 of 3 <123>
