![]() | Home > Maintenance & Modifications > Wiring a blue sea fuse box properly. |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
So I'm keeping this defender forever, I've decided, and as such I'm turning an electrical corner. I want to go back and sure up a few of the electrical items I've fitted, this time using a proper auxiliary fuse box etc. (I've been known to use scotch locks, lots of tape and twisting wire ends together in the past haha)
So I've got a blue sea fuse box which I want to fit properly in the battery box. Can someone tell me (or point me in the direction of) how i should be wiring it into the battery please? ie: -fuse/no fuse btw battery and fuse box? (if so what size?) -thickness of wire? -how to connect to the terminals best? want this part to be "bulletproof" so I'm confident adding on whatever else in the future... cheers in advance Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
redzob Member Since: 16 Jul 2014 Location: St. Peter Port Posts: 137 ![]() ![]() ![]() |
I did the same and found that searching for "megafuse" on this forum was a pretty good start! Defender Puma 2.2 XS 90
Vespa GTS 300 Way too many racing bikes. |
Depends as Munch stated what you're intending to run off it and it's maximum current capacity. I connected mine (also Blue Sea which has I believe a 60 amp total rating) directly to the vehicle 100 amp mega fuse. I then subsequently placed a 60 amp fuse in line and ran that to the input of the fusebox on the basis that the smaller would naturally rupture first in the event of supply cable failure. If you go through life with your head in the sand....all people will see is an ar5e!!
Rule of thumb for larger cables 7-8amps/mm2
Blue Sea fuse boxes are rated at maximum of 100 amps per bank of 6 fuses so that is the largest fuse between battery and fuse box. If using a 12 gang fuse box spread the load as evenly as possible between the two banks of fuses. You do not want 6 x 30 amp fuses on one bank and 6 x 1 amp fuses on the other bank. HTH Brendan |
David if I can help with any bits 'n' bobs you may need just drop me a 'pm.'
![]() Couple of pictures....Suffering from mild OCD and having only one battery I placed the lot in an IP67 rated enclosure too with waterproof glands. I also ran an extra multicore cable from driver's side to passenger seatbox for any future additions as the cable would already be there. ![]() Click image to enlarge ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 ![]() ![]() ![]() |
I chopped up an old pair of cheep jump leads for the supply and ran it through a 50amp fuse, the type that audio buffs use. Obviously up the fuse rating if needed.
thanks so the help everyone so far! some good stuff to think about/read
K9F- may drop you a PM in the coming days or hours! leeds- thanks for that info, v helpful. An opportunity for you to sell a 'wiring kit' for the blue sea fuse boxes perhaps? I'm sure theres a few out there who are capable of wiring the odd bit, but would be happy to buy a ready-made kit for fitting the box to the battery itself? just a thought... Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Hi david, check out vehicle wiring products website. All the stuff you need is there.
I'm probably close to you in staff @ m6 j16 and have a bluesea and your welcome to come have a look how mine is fitted. Would happily give you a hand. |
David
You have a PM cheers Steve |
mike, thanks for that, having a look on their site - very good aren't they.
Should get most of what i need on there. Thanks for your offer too, if i get stuck ill drop you a PM ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
quick question that I'm sorry i could find the answer to!
buying a few bits, what size/dia. 'hole' do i need in the connector (the polo shaped one) which attaches to the main positive on the blue sea fuse box? i.e. the incoming +ve feed from the battery? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
I would recommend VWP too, especially for multiple bits and pieces.
The prices are very competitive and good quality, for smaller Canute cable I'd recommend thinwall too. Mal's photo example is great, always screams to me that you can tell a sparky co,pelted it too. MK junction box and all. ![]() |
this might help you.
![]() Click image to enlargeElectrical Setup v3 by mikeh501, on Flickr |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
This is my setup with two batteries, separation relay and mega fuse box under driver seat (LHD) and BlueSea fuse box under passenger seat. Must remember to fit terminal cover on battery
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
