Home > Maintenance & Modifications > Wiring a blue sea fuse box properly.
Cheshire110
So I'm keeping this defender forever, I've decided, and as such I'm turning an electrical corner. I want to go back and sure up a few of the electrical items I've fitted, this time using a proper auxiliary fuse box etc. (I've been known to use scotch locks, lots of tape and twisting wire ends together in the past haha)
So I've got a blue sea fuse box which I want to fit properly in the battery box. Can someone tell me (or point me in the direction of) how i should be wiring it into the battery please?
ie:
-fuse/no fuse btw battery and fuse box? (if so what size?)
-thickness of wire?
-how to connect to the terminals best?
want this part to be "bulletproof" so I'm confident adding on whatever else in the future...
cheers in advance Cheers, David
Post #378182 11th Dec 2014 7:35pm
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I did the same and found that searching for "megafuse" on this forum was a pretty good start! Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #378190 11th Dec 2014 7:54pm
munch90
fuse/no fuse btw battery and fuse box? (if so what size?) -- depends on what your running on it , and how short and protected the wire is to the fuse box , example if you fitting the fusebox along away away from the battery and had a long wire that could rub through then yes fuse the feed , if the fuse box is next to battery and good protected wire then possibly not
-thickness of wire? depends on what your running on it and might add later , and what might be on at the same time and how long etc
on the positive terminal there is a m8 threaded hole to put positive feed for fuse box on with a ring terminal , only use a short bolt as the threaded part isn't very thick
negs are you running back to battery box or picking earth from where the thing is you fit eg off body/chassis etc
if your going back to battery then I would cut the neg terminal off the fit a ring terminal to the earth wire (needs to be heavy duty and good crimp , poss not diy job ) and fit a neg terminal with a stud then bolt main earth to it and a earth wire for a bus bar terminal block for earths
Post #378192 11th Dec 2014 7:56pm
K9F
Depends as Munch stated what you're intending to run off it and it's maximum current capacity. I connected mine (also Blue Sea which has I believe a 60 amp total rating) directly to the vehicle 100 amp mega fuse. I then subsequently placed a 60 amp fuse in line and ran that to the input of the fusebox on the basis that the smaller would naturally rupture first in the event of supply cable failure. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #378204 11th Dec 2014 8:33pm
leeds
Rule of thumb for larger cables 7-8amps/mm2
Blue Sea fuse boxes are rated at maximum of 100 amps per bank of 6 fuses so that is the largest fuse between battery and fuse box.
If using a 12 gang fuse box spread the load as evenly as possible between the two banks of fuses. You do not want 6 x 30 amp fuses on one bank and 6 x 1 amp fuses on the other bank.
HTH
Brendan
Post #378205 11th Dec 2014 8:35pm
K9F
David if I can help with any bits 'n' bobs you may need just drop me a 'pm.' Thumbs Up
Couple of pictures....Suffering from mild OCD and having only one battery I placed the lot in an IP67 rated enclosure too with waterproof glands. I also ran an extra multicore cable from driver's side to passenger seatbox for any future additions as the cable would already be there.
Post #378206 11th Dec 2014 8:36pm
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
I chopped up an old pair of cheep jump leads for the supply and ran it through a 50amp fuse, the type that audio buffs use. Obviously up the fuse rating if needed.
Post #378211 11th Dec 2014 8:52pm
Cheshire110
thanks so the help everyone so far! some good stuff to think about/read
K9F- may drop you a PM in the coming days or hours!
leeds- thanks for that info, v helpful. An opportunity for you to sell a 'wiring kit' for the blue sea fuse boxes perhaps? I'm sure theres a few out there who are capable of wiring the odd bit, but would be happy to buy a ready-made kit for fitting the box to the battery itself? just a thought... Cheers, David
Post #378220 11th Dec 2014 9:17pm
mikeh501
Hi david, check out vehicle wiring products website. All the stuff you need is there.
I'm probably close to you in staff @ m6 j16 and have a bluesea and your welcome to come have a look how mine is fitted. Would happily give you a hand.
Post #378244 11th Dec 2014 10:15pm
David
You have a PM
cheers
Steve
Post #378270 11th Dec 2014 11:17pm
Cheshire110
mike, thanks for that, having a look on their site - very good aren't they.
Should get most of what i need on there.
Thanks for your offer too, if i get stuck ill drop you a PM Thumbs Up Cheers, David
Post #378277 11th Dec 2014 11:46pm
Cheshire110
quick question that I'm sorry i could find the answer to!
buying a few bits, what size/dia. 'hole' do i need in the connector (the polo shaped one) which attaches to the main positive on the blue sea fuse box? i.e. the incoming +ve feed from the battery? Cheers, David
Post #378278 11th Dec 2014 11:48pm
I would recommend VWP too, especially for multiple bits and pieces.
The prices are very competitive and good quality, for smaller Canute cable I'd recommend thinwall too.
Mal's photo example is great, always screams to me that you can tell a sparky co,pelted it too.
MK junction box and all.
Mr. Green
Post #378280 11th Dec 2014 11:52pm
mikeh501
this might help you.
Electrical Setup v3 by mikeh501, on Flickr
Post #378330 12th Dec 2014 9:49am
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
This is my setup with two batteries, separation relay and mega fuse box under driver seat (LHD) and BlueSea fuse box under passenger seat. Must remember to fit terminal cover on battery Embarassed
Post #378523 12th Dec 2014 9:42pm
