Home > Puma (Tdci) > problem with Horn
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
problem with Horn
Has anyone had problem with the Horn?
I have only one 'tone' on the horn when normally it should be '2 tone'.
Suddenly developed!
Any suggestions?
Joe
'El pepe flamenco' JLS
'El Pepe Flamenco'
Post #32901 25th May 2010 9:24am
dgardel
Italy
there are 2 "bell" one on the left headlamp and one on the left (you can see the little grill under the position light).
check the "bell" that doesn't work and check the wiring loom, connector...... removing the headlamp.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #32903 25th May 2010 9:34am
jlerra
Horn
Thanks, dgardel - will examine this today.
Regards
Joe
'El Pepe Flamenco' JLS
'El Pepe Flamenco'
Post #32916 25th May 2010 1:19pm
jlerra
Horn
No Luck!
Have checked the Horn on the left (LHD vehicle) - no sound coming out.
I think it may be the Horn itself or the wiring, although the connector and earth seem OK.
Joe JLS
'El Pepe Flamenco'
Post #32971 26th May 2010 8:11am
K9F
Don't want to teach anyone to 'suck eggs'......Swap the two horns over....easiest way to determine whether it's wiring or the horn itself. Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #32976 26th May 2010 9:06am
dgardel
Italy
Or put a 5W 12V bulb on the connector (car side) and try to "beeeep"................. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #33001 26th May 2010 1:28pm
Eduardo
Or a voltimeter to be more pro.... Eduardo
Post #33002 26th May 2010 1:33pm
K9F
Or your tongue, dick, finger or any other appendage you can get to fit, however in these instances you will of course need a second person to go 'beep flippin' beep!'
Rolling with laughter Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #33006 26th May 2010 1:46pm
Eduardo
Regarding the 2nd sentence It is only a matter of how long your appendages are Laughing Laughing Laughing Eduardo
Post #33019 26th May 2010 3:24pm
mse
and for fantastic access - take it from the rear Shocked Rolling with laughter
Remove the eyebrow and you will be able to see the horn wiring and remove easily - only through the plastic rivets (about 15 to push out and recover) Mike
Post #33032 26th May 2010 5:25pm
xatzhs
jlerra did you have any luck with this? I seem to have the same problem but haven't worked out which side it's not coming out of.
Post #89272 15th Sep 2011 5:27pm
jlerra
Horn problem
Hi,
Yes I fixed it - it was the 'high' tone horn, identified by exchanging the working horn for the suspect one. Bought one and replaced and fine again.
jlerra
El pepe flamenco JLS
'El Pepe Flamenco'
Post #89275 15th Sep 2011 5:37pm
