![]() | Home > Puma (Tdci) > problem with Horn |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Has anyone had problem with the Horn?
I have only one 'tone' on the horn when normally it should be '2 tone'. Suddenly developed! Any suggestions? Joe 'El pepe flamenco' JLS 'El Pepe Flamenco' |
there are 2 "bell" one on the left headlamp and one on the left (you can see the little grill under the position light).
check the "bell" that doesn't work and check the wiring loom, connector...... removing the headlamp.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Thanks, dgardel - will examine this today.
Regards Joe 'El Pepe Flamenco' JLS 'El Pepe Flamenco' |
No Luck!
Have checked the Horn on the left (LHD vehicle) - no sound coming out. I think it may be the Horn itself or the wiring, although the connector and earth seem OK. Joe JLS 'El Pepe Flamenco' |
Don't want to teach anyone to 'suck eggs'......Swap the two horns over....easiest way to determine whether it's wiring or the horn itself.
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Or put a 5W 12V bulb on the connector (car side) and try to "beeeep"................. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Or a voltimeter to be more pro.... Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Or your tongue, dick, finger or any other appendage you can get to fit, however in these instances you will of course need a second person to go 'beep flippin' beep!' ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
![]() ![]() Regarding the 2nd sentence It is only a matter of how long your appendages are ![]() ![]() ![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258 ![]() ![]() ![]() |
jlerra did you have any luck with this? I seem to have the same problem but haven't worked out which side it's not coming out of.
Hi,
Yes I fixed it - it was the 'high' tone horn, identified by exchanging the working horn for the suspect one. Bought one and replaced and fine again. jlerra El pepe flamenco JLS 'El Pepe Flamenco' |
