![]() | Home > Maintenance & Modifications > electric windows switch |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Hi
Did a search for this but couldn't find the answer ... if there is any ![]() In our Defenders - or at least on mine !- the window switch has to be pressed all time untill the window is up ... it only has one position. Can we make a modification to it, so that if we press the window switch for more than 1 1/2 second the window goes up alone (like my wife's Astra and almost every cars sold these days)? And if we press for a shorter period the window only goes up that little bit ... ? And if so, is it a simple thing to do ? ![]() Thanks Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
My classic range rover had this, probably wouldn't be to har to retro fit
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Im pretty sure the electric windows work through a ECU on most cars but the defender (well TD5 at least, pretty sure Puma ones too) is just a switch connected direct to the window motors. Would think the easiest thing would be to wire a window ECU from a RRC or Disco into the circuit.
Pete. |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
come on guys, i haven't got a clue how to do this but i like the idea so all i need is someone to do it, take some pictures and write a parts list, with maybe a link to the cheapest place to get them from, be at the end of the phone when i mess up then come around and for the price of a beer do it for me,
thats all ![]() |
I too don't have a clue on what you're saying ! ![]() ![]() And we can arrange to have a beer if I go there on hollidays or if you came here in the summer! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
joking aside, if anyone would happen to know of a cheap ecu and wiring diagram i think most of use could give it a try. and cool points to the first person to come up with the know how (fingers crossd someone will)
Think you will have to fit all the wiring from a Range Rover Classic between the power supply, switches and window motor.
Personally i can keep my finger on the switch for a few seconds and dont want to change the wiring on my Defender but if anybody wants it doing then im sure i can do it for them. |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Humm
I remember that Ive seen some chinese systems of power windows (that are using to convert manual windows in electric ones) that have this "one touch" close and open window function. Im not sure if one of then can be installed inside the door. Found this one in internerd http://www.duettomotors.com/general/gen_power.htm Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
don't forget that auto up windows have the anti trap sensor fitted, so I don't know if the window would go down as soon as its fully closed without this on the fender
just a thought 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
Just bought THIS ONE
with current control for safety rules...... ![]() ![]() IID Pro MV License |
looks a good unit, you must let us know how you get on. |
Here installation instructions: http://files.me.com/daniele.gardellin/nnoktb
Here mod for heavy windows (from DEI Builder): http://files.me.com/daniele.gardellin/gqa7ve Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 26th May 2010 5:42pm. Edited 1 time in total |
![]() ![]() ![]() ![]() IID Pro MV License |
Ahh...the man we're all waiting to hear from ! ![]() Very nice kit ! ![]() When you fit it let us know your feedback ... I'll buy one too, just have too see if I'm capable of fitting it or will have to take it to someone who knows how. The Mrs. will be very happy to know that there's a solution for "her" problem!! ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
