Home > Maintenance & Modifications > electric windows switch
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Hi
Did a search for this but couldn't find the answer ... if there is any Very Happy ...
In our Defenders - or at least on mine !- the window switch has to be pressed all time untill the window is up ... it only has one position. Can we make a modification to it, so that if we press the window switch for more than 1 1/2 second the window goes up alone (like my wife's Astra and almost every cars sold these days)? And if we press for a shorter period the window only goes up that little bit ... ?
And if so, is it a simple thing to do ? Very Happy
Thanks Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #32848 24th May 2010 3:11pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
My classic range rover had this, probably wouldn't be to har to retro fit
Post #32853 24th May 2010 5:20pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Im pretty sure the electric windows work through a ECU on most cars but the defender (well TD5 at least, pretty sure Puma ones too) is just a switch connected direct to the window motors. Would think the easiest thing would be to wire a window ECU from a RRC or Disco into the circuit.
Pete.
Post #32881 24th May 2010 9:45pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
come on guys, i haven't got a clue how to do this but i like the idea so all i need is someone to do it, take some pictures and write a parts list, with maybe a link to the cheapest place to get them from, be at the end of the phone when i mess up then come around and for the price of a beer do it for me,
thats all Wink
Post #32888 24th May 2010 10:47pm
lrmaniac
Zinke wrote:
Would think the easiest thing would be to wire a window ECU from a RRC or Disco into the circuit. Pete.
I too don't have a clue on what you're saying ! Whistle But as double cab happy said a pic or a part number and a more exhaustive explanation would be welcome !! Thumbs Up
And we can arrange to have a beer if I go there on hollidays or if you came here in the summer! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #32906 25th May 2010 10:41am
double cab happy
joking aside, if anyone would happen to know of a cheap ecu and wiring diagram i think most of use could give it a try. and cool points to the first person to come up with the know how (fingers crossd someone will)
Post #32939 25th May 2010 7:35pm
Zinke
Think you will have to fit all the wiring from a Range Rover Classic between the power supply, switches and window motor.
Personally i can keep my finger on the switch for a few seconds and dont want to change the wiring on my Defender but if anybody wants it doing then im sure i can do it for them.
Post #32959 25th May 2010 10:19pm
Eduardo
Humm
I remember that Ive seen some chinese systems of power windows (that are using to convert manual windows in electric ones) that have this "one touch" close and open window function.
Im not sure if one of then can be installed inside the door.
Found this one in internerd
http://www.duettomotors.com/general/gen_power.htm
Cheers Eduardo
Post #32960 25th May 2010 11:10pm
mse
Pete.
You are correct - there is an ecu that controls the auto up and auto down functions.
im not sure about down, but it might also need a switch to say "im down" for the ECU - if you find an auto up (not a RRC or Disco 1/2 option) you also need a "im at the top" switch that basically senses pressure Mike
Post #32968 26th May 2010 7:49am
Grockle
don't forget that auto up windows have the anti trap sensor fitted, so I don't know if the window would go down as soon as its fully closed without this on the fender
just a thought 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #32984 26th May 2010 9:43am
dgardel
Italy
Just bought THIS ONE
with current control for safety rules......
Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #33030 26th May 2010 5:25pm
nicks
Thumbs Up
looks a good unit, you must let us know how you get on.
Post #33033 26th May 2010 5:33pm
dgardel
Italy
Here installation instructions: http://files.me.com/daniele.gardellin/nnoktb
Here mod for heavy windows (from DEI Builder): http://files.me.com/daniele.gardellin/gqa7ve Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #33034 26th May 2010 5:41pm
dgardel
Italy
Thumbs Up
Mr. Green when its will arrive I'll let you (all forum) know Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #33035 26th May 2010 5:42pm
lrmaniac
dgardel wrote:
Thumbs Up
Ahh...the man we're all waiting to hear from ! Mr. Green
Very nice kit ! Thumbs Up
When you fit it let us know your feedback ... I'll buy one too, just have too see if I'm capable of fitting it or will have to take it to someone who knows how. The Mrs. will be very happy to know that there's a solution for "her" problem!! Bow down Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #33076 27th May 2010 9:35am
