Home > Puma (Tdci) > Immobilizing a Puma temporarily |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 666 |
Turn it off, lock and put key in pocket
21st May 2010 7:03pm |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 530 |
Way too easy |
21st May 2010 7:13pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
A couple of ideas for you.
A hidden micro switch which is wired into the fuel pump/ignition etc Another idea is a battery isolator switch. Put say a 10 amp fuse bridging the contacts. This will keep the alarm/radio settings etc. Anyone trying to hotwire it will blow the fuse . Am sure there are other ideas Physical deterrents include disclock, bullock pedal locks etc HTH Brendan |
21st May 2010 7:56pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Leave the the transfer box in neutral or leave a in it NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
21st May 2010 10:11pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2262 |
You canīt leave any animal smaller than a rhino inside. You know why. Puma 110" SW
............................................................. Earth first. Other planets later Last edited by MK on 22nd May 2010 11:22am. Edited 1 time in total |
21st May 2010 11:12pm |
Go ed enlighten me NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
21st May 2010 11:22pm |
http://www.defender2.net/forum/topic3145.html?highlight=toyota Puma 110" SW
21st May 2010 11:33pm |
What the you on about....you need to stop smoking that NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
22nd May 2010 12:53am |
Puma 110" SW
22nd May 2010 1:34am |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 |
I think he means anything smaller than a Rhino will escape through the panel gaps
22nd May 2010 7:17am |
Aaaahhhhh very good i am a thick northerner u no NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
22nd May 2010 11:39am |
