![]() | Home > Puma (Tdci) > Immobilizing a Puma temporarily |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672 ![]() ![]() ![]() |
Turn it off, lock and put key in pocket
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588 ![]() ![]() ![]() |
Way too easy ![]() |
A couple of ideas for you.
A hidden micro switch which is wired into the fuel pump/ignition etc Another idea is a battery isolator switch. Put say a 10 amp fuse bridging the contacts. This will keep the alarm/radio settings etc. Anyone trying to hotwire it will blow the fuse . Am sure there are other ideas Physical deterrents include disclock, bullock pedal locks etc HTH Brendan |
Leave the the transfer box in neutral
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2488 ![]() ![]() ![]() |
You canīt leave any animal smaller than a rhino inside. You know why. Puma 110" SW
............................................................. Earth first. Other planets later Last edited by MK on 22nd May 2010 11:22am. Edited 1 time in total |
Go ed enlighten me NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
http://www.defender2.net/forum/topic3145.html?highlight=toyota Puma 110" SW
What the
![]() ![]() ![]() ............................................................. Earth first. Other planets later |
harveyg77 Member Since: 09 Apr 2010 Location: Derby Posts: 309 ![]() ![]() |
I think he means anything smaller than a Rhino will escape through the panel gaps
Aaaahhhhh
