Home > Puma (Tdci) > Oil leak
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Oil leak
Just wondered if you reckon changing the clutch could bring on a rear output shaft leak Shocked as it's leaking from prop shaft now 3 weeks after a new clutch and the seal was new in march.
Post #375569 1st Dec 2014 6:31pm
Who did the work? A main dealer should do that under warranty if it was caused by that, of course, you have to determine that it certainly was.
Post #375571 1st Dec 2014 6:32pm
mick
Main dealer the part is covered under 12 month warranty
My point is it started leaking after new clutch
Post #375592 1st Dec 2014 7:17pm
You could then argue that, if it started after the repair it's likely that it was / is caused by their work thus their responsibility.
Post #375598 1st Dec 2014 7:40pm
mick
That's what I am planning
Post #375617 1st Dec 2014 8:14pm
Thumbs Up
Post #375624 1st Dec 2014 8:22pm
munch90
if your talking about a rear prop flange on the transfer box , I cant see how doing a clutch would make the seal leak even if you took the handbrake drum off then the back plate off , cant really see how you could damage it
Post #375649 1st Dec 2014 9:08pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
as munch90 says really changing the clutch shouldent have an effect on the seal only if the breather pipe for the transfer box has been trapped.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #375686 1st Dec 2014 10:27pm
mick
All sorted now new seal and park brake shoes all FOC big thanks to Guy Salmon
Post #376457 4th Dec 2014 9:32pm
