![]() | Home > Puma (Tdci) > Oil leak |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Who did the work? A main dealer should do that under warranty if it was caused by that, of course, you have to determine that it certainly was.
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Main dealer the part is covered under 12 month warranty
My point is it started leaking after new clutch |
You could then argue that, if it started after the repair it's likely that it was / is caused by their work thus their responsibility.
That's what I am planning
if your talking about a rear prop flange on the transfer box , I cant see how doing a clutch would make the seal leak even if you took the handbrake drum off then the back plate off , cant really see how you could damage it
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
as munch90 says really changing the clutch shouldent have an effect on the seal only if the breather pipe for the transfer box has been trapped.
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
All sorted now new seal and park brake shoes all FOC big thanks to Guy Salmon
