Home > Technical > Battery in the BBUS
YeomanOfTheBar
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Battery in the BBUS
So, my truck has been in to have a bit of an audio upgrade with some installers who apparently aren't aware that it has a BBUS. Obviously, once they disconnected the battery the alarm started wailing at them, but instead of reading the manual and figuring how to do it properly, they decided to let the thing run until the battery died.
Now that everything is reconnected, is the BBUS going to recharge and work properly, or is it going to have problems as its battery has been fully discharged? 2013 Defender 110 XS DCPU
Post #371592 14th Nov 2014 9:33am
munch90
think they only charge when your running , so think I would leave it and try it in maybe a few days time ( depending on how much you use the defender ) just try disconnecting the main battery after a few days
Post #371596 14th Nov 2014 9:58am
Yes, it should recharge pretty quickly in normal use. I suggest that after a few of days of normal running you set the alarm off and check that the BBUS makes a noise. If it doesn't, replace it and present the installer with the bill.
Post #371598 14th Nov 2014 10:21am
Cupboard
Out of interest, how long did the battery last for?
Post #371656 14th Nov 2014 6:27pm
YeomanOfTheBar
They didn't say exactly, but reckoned it was about 10-15 minutes. 2013 Defender 110 XS DCPU
Post #371658 14th Nov 2014 6:35pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
^^^ that's interesting, as last time I disconnected my battery I couldnt stop the alarm going off despite using the correct sequence for battery disconnecting. After a few (2-3 mins) the alarm stopped, I just assumed the sequence finally worked, but perhaps the BBUS just ran out of juice.
I guess the battery in there has a limited lifespan..?
Simon
Post #371696 14th Nov 2014 9:32pm
munch90
Isnt there some ruling that alarms are only allowed to go off for a set time ,
Post #371706 14th Nov 2014 10:11pm
