![]() | Home > Technical > Battery in the BBUS |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
think they only charge when your running , so think I would leave it and try it in maybe a few days time ( depending on how much you use the defender ) just try disconnecting the main battery after a few days
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18052
Yes, it should recharge pretty quickly in normal use. I suggest that after a few of days of normal running you set the alarm off and check that the BBUS makes a noise. If it doesn't, replace it and present the installer with the bill.
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Out of interest, how long did the battery last for?
| YeomanOfTheBar Member Since: 04 Nov 2012 Location: North Notts Posts: 210
They didn't say exactly, but reckoned it was about 10-15 minutes. 2013 Defender 110 XS DCPU
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
^^^ that's interesting, as last time I disconnected my battery I couldnt stop the alarm going off despite using the correct sequence for battery disconnecting. After a few (2-3 mins) the alarm stopped, I just assumed the sequence finally worked, but perhaps the BBUS just ran out of juice.
I guess the battery in there has a limited lifespan..? Cheers Simon |
Isnt there some ruling that alarms are only allowed to go off for a set time ,
| All times are GMT |
