![]() | Home > Technical > TD5 XS 110 heater / air con |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
In a Td5 you have two seperate systems.
Heater. On the left of the instrument binnacle you have off, open, speed one and speed two. On the right of the binnacle you have screen, screen and feet, feet, and also a variable hot to cold. Air con. Under dash unit. Three fan speeds and amount of cold. The two units are completely seperate. Andy |
| martyp1970 Member Since: 21 Oct 2014 Location: Cramlington Posts: 40
So would you recommend just using the top normal heaters,
the airco is that just cold air. |
Yes. Use the top controls to warm feet and demist just the front screen, and use the lower section to get a cold knee, and freezing keys
Andy |
| All times are GMT |
