Home > Technical > TD5 XS 110 heater / air con
martyp1970
United Kingdom 2006 Defender 110 Td5 XS CSW Blenheim Silver
After some advice about my heater,
I have a MY06 110 XS td5,
im a little confused with the heater , air con.
ok I'll have the top left control on fuul down, on the left I'll have it on pointing up to the screen and on the hot, red section.
underneath the dash to my tight I take it is the air con,
put that on say number 2.
its sh*t theres no other way to describe it haha.
I need some advice on getting more out of it, heat wise, or replacing it !.
Any advice plus links to info would be appreciated.
I've had a session with a flexible clear silcone this moring trying to stay dry too Rolling Eyes
Post #370623 9th Nov 2014 8:28pm
landy andy
In a Td5 you have two seperate systems.
Heater. On the left of the instrument binnacle you have off, open, speed one and speed two. On the right of the binnacle you have screen, screen and feet, feet, and also a variable hot to cold.
Air con. Under dash unit. Three fan speeds and amount of cold.
The two units are completely seperate.
Andy
Post #370653 9th Nov 2014 9:33pm
martyp1970
So would you recommend just using the top normal heaters,
the airco is that just cold air.
Post #370663 9th Nov 2014 10:10pm
landy andy
Yes. Use the top controls to warm feet and demist just the front screen, and use the lower section to get a cold knee, and freezing keys Rolling with laughter Rolling with laughter
Andy
Post #370692 9th Nov 2014 11:54pm
