Home > Puma (Tdci) > Latest issue with the 110
Page 2 of 2 <12
Eduardo
mse wrote:
Apparently the Turbo hoses are VERY thin - although im interested, obviously all diesels smoke - so is this more black smoke than normal, or all the time?
Yep, it is more black smoke all the time (the fisures in the hoses were quite little so we didnt get any smoke at all).
Mine is now repaired provisionally with high resistance tape until the spare arrives (I hope that the volcano doesnt delay the shipment).
BTW: Is it possible to replace those turbo hoses by other of better quality?
Cheers Eduardo
Post #32381 17th May 2010 1:06pm
110SEB
LRA have been out to us and the turbo has been thoroughly checked. All ok.
However the main culprits are (i) a little loose rattly bit of metal "a link bar" by the turbo dump valve which would rattle very fast when the dump valve is operating at higher revs, or (ii) the turbo bearings. I and the LRA technician (who could teach our dealership mechanics a few things) think that (i) will be the one. I hope so.
On the subject of pipe fissures I was informed that the biggest indicator of a failed turbo is black smoke staining on the back of the car from the muck coming out of the exhaust. None of that on ours.
I mentioned inlet manifold seal but apparently this didn't seem to be the problem.
I'll keep you posted.
Post #32393 17th May 2010 4:15pm
110SEB
Update:
They're still not happy with the diff they replaced. Something about a locating pin, but the service guy admitted not understanding the mechanics of it all.
We're also getting a whole new turbo now they agree the noise is not normal and they don't know what's causing it. It's defo turbo related though. At least they agree on that!
IMHO, they're not ******* normal Big Cry Mad
Post #32649 20th May 2010 3:42pm
110SEB
Last update before I leave this one alone. Diff locating pin sorted, but the dealers identified what the turbo problem was: watch out for your turbo actuators before you warranties run out, guys.
It sounds to me like a kind of trigger or clutch to the turbo. It was broken and damaged the rest of the turbo. Perhaps the turbo is not as strong as they had hoped.
All sorted and back from the dealers.
Post #33187 28th May 2010 3:05pm
dgardel
Italy
110SEB wrote:
.........watch out for your turbo actuators before you warranties run out, guys.
Could you explain me better? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #33190 28th May 2010 4:29pm
Page 2 of 2 <12
