![]() | Home > Puma (Tdci) > Advice needed |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 ![]() ![]() |
If it's a 60 plate hen it's still within the 6 year corrosion warranty so get it in and done under warranty! In June this year I had over 5k of bodywork done on an 09 90 due to corrosion, it ended up having a new complete roof, bulkhead painted, wind screen frame,body cappings and rear panels painted,all done under the warranty.
Was a nightmare to start with as my local dealer are renowned for being more than useless but Sarah at lrcs soon sorted the issues out ![]() |
Gleaney Member Since: 03 Dec 2012 Location: Earth! Posts: 94 ![]() ![]() ![]() |
Thanks for that. That's sort of what I'm thinking.Though I did look at a 1 year old one yesterday and it was way worse than mine. I'm just sort of thinking that when I get it done it will just return again.
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
It is a standard issue on just about all defenders as far as I know. Had mine repainted as well.
Ok. Just to keep you updated. Landrover have agreed to do all the corrosion on warranty. With new side steps and grill.Corrosion around the Alpine window and wind screen.
V5 ROT Member Since: 09 Jan 2016 Location: Oxfordshire Posts: 14 ![]() ![]() ![]() |
I've just got a 10 plate (registered 01/03/2010), its bubbling around the front screen & alpine windows. Only a couple of weeks until it's 6 years old!!
Will LR cover the warranty?? |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1320 ![]() ![]() |
short answer is Yes...
as long as you have had the regular corrosion check ups at the dealers? Clemmo ![]() |
