Home > Puma (Tdci) > Advice needed
Gleaney
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Advice needed
Hi there. I'm suffering with bubbling paint to around the windscreen. It's a 60 plate defender and has had the screen surround replaced already. And re sprayed again ! And yet again it's returned. I'm just considering to get it done again or just to leave it. As it will probably happen again. Also there a signs of bubbling around the Alpine window.
Bow down
Post #366201 21st Oct 2014 5:24pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
If it's a 60 plate hen it's still within the 6 year corrosion warranty so get it in and done under warranty! In June this year I had over 5k of bodywork done on an 09 90 due to corrosion, it ended up having a new complete roof, bulkhead painted, wind screen frame,body cappings and rear panels painted,all done under the warranty.
Was a nightmare to start with as my local dealer are renowned for being more than useless but Sarah at lrcs soon sorted the issues out Thumbs Up
Post #366221 21st Oct 2014 6:24pm
Gleaney
Thanks for that. That's sort of what I'm thinking.Though I did look at a 1 year old one yesterday and it was way worse than mine. I'm just sort of thinking that when I get it done it will just return again.
Post #366233 21st Oct 2014 7:15pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
It is a standard issue on just about all defenders as far as I know. Had mine repainted as well.
Post #366256 21st Oct 2014 7:57pm
Gleaney
Ok. Just to keep you updated. Landrover have agreed to do all the corrosion on warranty. With new side steps and grill.Corrosion around the Alpine window and wind screen.
Post #370637 9th Nov 2014 9:00pm
bga86
Thumbs Up
Post #370643 9th Nov 2014 9:14pm
V5 ROT
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I've just got a 10 plate (registered 01/03/2010), its bubbling around the front screen & alpine windows. Only a couple of weeks until it's 6 years old!!
Will LR cover the warranty??
Post #504322 13th Feb 2016 5:42pm
Clemmo
short answer is Yes...
as long as you have had the regular corrosion check ups at the dealers?
Clemmo Thumbs Up
Post #504432 13th Feb 2016 11:41pm
