![]() | Home > Puma (Tdci) > Bonnet top (not wing top) chequer plate? |
There is some in the lockup waiting to get fitted to mine, but we have been busy fitting the demo Maggiolina rooftents to the vehicles ready for Driffield so it will probably not get done before we go, as the next few days will be spent packing the trailer and sorting out everything that is getting taken. However it will probably be one of the first jobs when we get back. The 110 already has the wingtop chequer plated in black, it looks and feels really good so I should think the bonnet will get matching treatment. When it gets done, I will take some pics. Barbara Using Brendan's login as mine isn't working -probably because I tried to login with the wrong password too many times ![]() |
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 ![]() ![]() |
Done it and works great, though I added a layer of neoprene rubber underneath to protect the bonnet. I also fitted it with pop rivets as it would be hard to fiddle with nuts under the bonnets framework. Make sure you paint over the edges of the holes first!
Pop rivets is the spawn of the devil as far as overland vehicles are concerned. On our red 110 overland vehicle some of the pop rivets holding the bonnet chequer plate on have popped. they will be replaced with stainless nyloc or rivnuts
Brendan |
I notice from the thread by caribcat on towing that he has bonnet chequer plate. Maybe a PM will get you some photos
![]() Encourage him to post them here ![]() + New Defender 110 First Edition |
Not much to see really. Underneath 80% of the rivets are hidden behind the steel frame work of the Puma bonnet. Notice the medical neoprene as a gasket (google search -hard to find though and can't remember my supplier)
Leeds, I have to disagree with the pop rivet issue. There are literally hundreds of rivets on any generation of Land Rover so you are fighting a losing battle! After 30k of overland I have never had a failure -even on desert roads which would shake your teeth out! Your issue might be that you are not using a gasket between plate and bonnet which dampens vibrations and removes any movement. Rivnuts are not an option for everyone because of the cost of a tool and anything made of stainless is the kiss of death when in contact with alloy. Alloy machine screws are blinkin' expensive (especially ones in black as would look good here) and there is no way to attach the nut without cutting an access hole in the frame. The humble pop rivet is cheap and workable. If it breaks you replace it in 30 seconds. Also on overland trips a sheet of alloy stored under the rear mat and little pack of pop rivets +5mm drill will do a host of body repairs so tend to have one at hand anyway. Hope this helps, Tom ![]() Click image to enlarge[/img] ![]() Click image to enlarge [/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Thank you very much for the clear pics Caribcat
Brain has been frazzled by long hours getting ready for a show Should have said self tappers are the devils spawn and not pop rivets. Yep lots of pop rivets in a Land Rover However have popped some pop rivets on the bonnet chequer plate. As for desert roads etc,Have had my fair share of them and have had various vibration issues. On one 25,000 mile trip suffered metal fatigue and failure of both rear brake stone guards, bonnet stay fastening bracket, had a hole in top of rad from bolt in rad retaining frame. Self tappers lost by the dozen. I hate them Cost of rivnut tooling is not great at about �50. Never had need for ali sheet to repair body damage on a trip yet. Have had to do more major work like chassis replacement. ![]() ![]() Our 14 year old 200,000 mile overland vehicle has just been put in for its MOT with no preparation. Needed rear fog light connector sorted and alignment of one headlamp. Not bad really when consider both its age and the treatment it gets ![]() ![]() Brendan PS if anyone wants to see what we get up to have a look HERE. Make yourself comfortable with tea/coffee/beer first |
My car's done nearly 20,000 miles and I've not had to replace the chassis or patch any bodywork yet
![]() I like the look of the chequer plate, though. Does it add much strength to the bonnet? If I were standing on it, would the bulge collapse (plate doesn't add any strength to the sides)? One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
The bonnet is strong anyway, but the chequer definitely adds strength. Strong enough to walk on.
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I do see what they are doing with those plates but still a lot of the bonnet isn't covered and from experience sods law means you will end up catching/ scratching the non-chequer plate bits.
Just to throw this one in there- Mammouth 4x4 bonnet chequer plate: ![]() Click image to enlarge Glyn :sheep: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Gav110 Member Since: 14 Feb 2010 Location: Sydney Posts: 16 ![]() ![]() |
Thanks for the photo! I have been waiting to see one since March when their '1 piece' product was supposed to be released; and despite their promises they have neither sent me any nor posted them on their site (unless I'm blind). Are there any other shots of it - ideally installed on a vehicle? Also anyone know pricing? Thanks Gavster 2010 Puma 110 |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Like my Tonga Green too much to put stuff on it. I'm thinking of replacing the silver that the former owner put on my XS's sides with black, as holes are already there... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
