![]() | Home > Technical > LT77 gearbox |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6202 ![]() ![]() ![]() |
Should just screw into place. assuming they had drilled and tapped the hole for it.
Is yours the suffix 51A with lower ratio 1st & 2nd gears? That was the only difference between civvy and military LT77's. |
Matt4D Member Since: 05 Jul 2014 Location: Derbyshire Posts: 3 ![]() ![]() |
Thank you Jim will have a good look
