Home > Technical > LT77 gearbox
Matt4D
LT77 gearbox
I have a ex military defender with a LT77 gearbox it has no reverse switch fitted is it a big job to fit or is it just screw a switch into place
atb Matt
Post #359306 21st Sep 2014 9:05pm
Should just screw into place. assuming they had drilled and tapped the hole for it.
Is yours the suffix 51A with lower ratio 1st & 2nd gears? That was the only difference between civvy and military LT77's.
Post #359378 22nd Sep 2014 7:52am
Matt4D
Thank you Jim will have a good look
Post #359486 22nd Sep 2014 5:21pm
