![]() | Home > Maintenance & Modifications > Fault codes after tuned ECU. |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Thanks Andy, ill have a few lazer cut with 19mm holes.
Pete |
Robofarmer Member Since: 17 Mar 2010 Location: cheshire Posts: 88 ![]() ![]() ![]() |
Thanks for that info mr woo had know idea about the three driving cycles !! am going to try a 19mm hole like andrew s reconmends clear all codes again and see what happens. if you anywere near tonight mr woo come and take mine for a run and check out it stuttering at about 2500rmp . only with the remap on. any idea,s ??? ![]() ![]() ![]() |
Please do! Willing volunteer here if you do! New EGR Valve fitted this week after having to call LR Assist week before, lost remap as result....Sick to the back teeth of EGR Valve issues and fallout thereof. Please, please, please if someone has a suitable blank manufactured or about to do so with the much researched 19 mm hole in, send me one or let me know how much remuneration you would like for one. Mr Woo what was your resolution in perfecting the perfect plate? Did you too end up with a 19mm hole or thereabouts? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
k9F how did you lose your map? did you not put the std back on before it went in ? or were there other issues i,d like to know as mine mite have to go in .
I have/had an Autologic remap that doesn't give the vehicle owner the capability of reverting back to standard at home. Once installed if lost/overwritten you can go back to any Autologic dealer and get it reinstalled free gratis.
I am more than happy with the performance/fuel economy increases (it is a phenominal difference) and had it done prior to joining this site and finding out about Pete from BAS's option. For convenience have to admit BAS seems better, but having already shelled out will not do so again, will stick with what I have. Maybe next vehicle Pete? ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Add me to the list if there is one Pete ![]() Bob |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Yep 19mm just as a further note and to prove there greatness I ran for 48k miles with a partially blanked plate, some of those miles I dont know how many were with a broken EGR valve. This had no affect on my performance as the engine was getting all the ambient air it needed. ![]() The only reason I had a new EGR in the end was becuase the 90 was in for something else and Land Rover replaced it, I didn;t want or more improtantly need a new EGR. When mine is out of wrrantly I am going to rip out all the EGR plumbing, blank the recirculation completely and pay Pete to sort out the MIL light. |
me too so we can cut the 50% the expences... ![]() ![]() IID Pro MV License |
JMS Member Since: 05 Mar 2010 Location: Isle of Wight Posts: 40 ![]() ![]() ![]() |
K9F What happened to cause the LR assist call out? Mine goes in tomorrow with, I assume EGR issues and assume I will also lose the Autologic remap. Power lag between 1800 - 2300rpm and black smoke during this range when some right foot applied? MIL came on Friday and was throwing Turbo over boost and MAF out of range fault codes. I had to turn the car off twice on my way from the Isle of Wight to Guildford, same again on the return as the car had gone into "limp home" mode. Quite annoying when you pull out to overtake, give it some right foot and ![]() ![]() Conclusion is EGR seems to be a pain in the Ar5e and a problem for most of us on here. Having just given Brown £435 for another 12mths I am more than happy to say bye bye to the EGR. Add me to the list please Pete. ![]() JMS |
Me too Pete (your iind Italian friend ![]() ![]() IID Pro MV License |
It was a 'hard latch' MIL light. I did not however go into 'limp mode.' No worries about the Autologic remap I have been assured that as soon as they have 'overcome' the gremlins created by the recent Land Rover software upgrades I shall have it reloaded free gratis when it is compatable. Have to admit though with the software upgrades and no remap mid-range acceleration is still better than it was prior remap, still miss the extra 80NM of torque and 30BHP though. ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2497 ![]() ![]() ![]() |
Does the driveline resist those extra power&torque given by remaps? Puma 110" SW
![]() ![]() Back to 'normal' now but I yearn for the day it can be reinstalled. ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
ian964 Member Since: 01 Jan 2010 Location: Surrey Posts: 30 ![]() ![]() ![]() |
Another one here with these fault code - MIL light came on this evening, fault codes are:
0100 0234 0299 0404 1103 1402 The car seemed to run fine (with BAS remap), I've now cleared the code, will see how it is in the morning. |
