Home > Maintenance & Modifications > Fault codes after tuned ECU.
Page 2 of 3 <123>
bell-auto-services
Thanks Andy, ill have a few lazer cut with 19mm holes.
Pete
Post #30541 22nd Apr 2010 11:21pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Just to let everyone know, if the MIL light is going to come on after blanking it will do it after 3 driving cycles not by just traking it for a run.
I spent quite a bit of time like AndrewS perfecting the perfect plate that didn't put the MIL light on and I am convinced the engine runs much smoother and quieter!
Post #30551 23rd Apr 2010 7:38am
Robofarmer
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I spent quite a bit of time like AndrewS perfecting the perfect plate that didn't put the MIL light on and I am con nced the engine runs much smoother and quieter!
Thanks for that info mr woo had know idea about the three driving cycles !! am going to try a 19mm hole like andrew s reconmends clear all codes again and see what happens. if you anywere near tonight mr woo come and take mine for a run and check out it stuttering at about 2500rmp . only with the remap on. any idea,s ??? Confused Confused Confused
Post #30554 23rd Apr 2010 8:03am
K9F
bell-auto-services wrote:
I wonder if i should get some more EGR blanks cut for some group tests. Pete
Please do!
Willing volunteer here if you do! New EGR Valve fitted this week after having to call LR Assist week before, lost remap as result....Sick to the back teeth of EGR Valve issues and fallout thereof.
Please, please, please if someone has a suitable blank manufactured or about to do so with the much researched 19 mm hole in, send me one or let me know how much remuneration you would like for one.
Mr Woo what was your resolution in perfecting the perfect plate? Did you too end up with a 19mm hole or thereabouts? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30557 23rd Apr 2010 8:19am
Robofarmer
k9F how did you lose your map? did you not put the std back on before it went in ? or were there other issues i,d like to know as mine mite have to go in . Rolling Eyes Rolling Eyes
Post #30560 23rd Apr 2010 8:29am
K9F
I have/had an Autologic remap that doesn't give the vehicle owner the capability of reverting back to standard at home. Once installed if lost/overwritten you can go back to any Autologic dealer and get it reinstalled free gratis.
I am more than happy with the performance/fuel economy increases (it is a phenominal difference) and had it done prior to joining this site and finding out about Pete from BAS's option. For convenience have to admit BAS seems better, but having already shelled out will not do so again, will stick with what I have. Maybe next vehicle Pete?
Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30563 23rd Apr 2010 8:56am
bob neville
Please do!
Add me to the list if there is one Pete Thumbs Up
Bob
Post #30564 23rd Apr 2010 9:17am
mrwoo
Please do!
Yep 19mm just as a further note and to prove there greatness I ran for 48k miles with a partially blanked plate, some of those miles I dont know how many were with a broken EGR valve. This had no affect on my performance as the engine was getting all the ambient air it needed. Thumbs Up
The only reason I had a new EGR in the end was becuase the 90 was in for something else and Land Rover replaced it, I didn;t want or more improtantly need a new EGR.
When mine is out of wrrantly I am going to rip out all the EGR plumbing, blank the recirculation completely and pay Pete to sort out the MIL light.
Post #30580 23rd Apr 2010 12:23pm
dgardel
Italy
me too so we can cut the 50% the expences... Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #30608 23rd Apr 2010 6:30pm
JMS
England 2011 Defender 110 Puma 2.4 USW Stornoway Grey
K9F
What happened to cause the LR assist call out? Mine goes in tomorrow with, I assume EGR issues and assume I will also lose the Autologic remap.
Power lag between 1800 - 2300rpm and black smoke during this range when some right foot applied?
MIL came on Friday and was throwing Turbo over boost and MAF out of range fault codes.
I had to turn the car off twice on my way from the Isle of Wight to Guildford, same again on the return as the car had gone into "limp home" mode. Quite annoying when you pull out to overtake, give it some right foot and Censored the car slows down rather than speeds up! Switching off and re-starting cleared the "limp home" problem for about 20 miles.....Banging Head
Conclusion is EGR seems to be a pain in the Ar5e and a problem for most of us on here.
Having just given Brown £435 for another 12mths I am more than happy to say bye bye to the EGR. Add me to the list please Pete. Bow down
JMS
Post #30691 25th Apr 2010 8:01pm
dgardel
Italy
Me too Pete (your iind Italian friend Whistle ) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #30696 25th Apr 2010 9:14pm
K9F
JMS wrote:
K9F What happened to cause the LR assist call out? JMS
It was a 'hard latch' MIL light. I did not however go into 'limp mode.' No worries about the Autologic remap I have been assured that as soon as they have 'overcome' the gremlins created by the recent Land Rover software upgrades I shall have it reloaded free gratis when it is compatable.
Have to admit though with the software upgrades and no remap mid-range acceleration is still better than it was prior remap, still miss the extra 80NM of torque and 30BHP though.
Post #30716 26th Apr 2010 7:44am
MK
Does the driveline resist those extra power&torque given by remaps? Puma 110" SW
Post #30730 26th Apr 2010 11:51am
K9F
Question Not really sure of the context of your question, Question nevertheless my vehicle felt like it had a rocket up it's ar5e after the remap was programmed in. The speed limiter was removed and the drivability of the vehicle was much improved over standard, not to mention the improved fuel consumption.
Back to 'normal' now but I yearn for the day it can be reinstalled. Dog Thumbs Up Dog If you go through life with your head in the sand....all people will see is an ar5e!!
Post #30739 26th Apr 2010 2:03pm
ian964
Another one here with these fault code - MIL light came on this evening, fault codes are:
0100
0234
0299
0404
1103
1402
The car seemed to run fine (with BAS remap), I've now cleared the code, will see how it is in the morning.
Post #30766 26th Apr 2010 11:00pm
Page 2 of 3 <123>
