Home > Maintenance & Modifications > Rubber to prevent rattling
Waldo
Currently looking at buying some rubber/spongey material to stop the lid from vibrating/rattling on my cubby and then also the T_box i'm making.
What sort should I get??
Looking at this companies ebay shop as they have quite a range if different types
http://stores.ebay.co.uk/mantekdirect/ Defender 90 XS TD5 (03 Reg)
Post #351539 14th Aug 2014 9:53am
Carpet the underside will do the trick.
OR get an elastic strip across the top like I have to stop the Sub rattling the lid shout.
I have both of these ideas combined and they do the trick!
Thumbs Up
Post #351543 14th Aug 2014 10:21am
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I'm using some rubbery pond liner. its thin, you can cut it to shape very easily and lasts for years. 1953 80"
1987 mini city e
2011 90"
Post #351662 14th Aug 2014 9:39pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Or maybe neoprene. Pretty cheap on eBay and available in different colours. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #351679 14th Aug 2014 10:18pm
Harry.O
I did the edges of the seatbox lids, floor panels, transmission tunnel etc with a roll of 5mm thick closed cell foam approx 15mm wide. It's held up really well and a 10m roll is only a few pounds from ebay.
Post #351805 15th Aug 2014 5:49pm
I've got some of that above from eBay trouble is the adhesive is rubbish, if it gets warm it'd move about.
I guess though it was very cheap so I won't complain.
Post #351806 15th Aug 2014 6:09pm
Waldo
Thanks a lot chaps
I like the idea of the neoprene so I'll see how that turns out Defender 90 XS TD5 (03 Reg)
Post #351892 16th Aug 2014 8:36am
