![]() | Home > Maintenance & Modifications > Rubber to prevent rattling |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Currently looking at buying some rubber/spongey material to stop the lid from vibrating/rattling on my cubby and then also the T_box i'm making.
What sort should I get?? Looking at this companies ebay shop as they have quite a range if different types http://stores.ebay.co.uk/mantekdirect/ Defender 90 XS TD5 (03 Reg) |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 264 ![]() ![]() ![]() |
I'm using some rubbery pond liner. its thin, you can cut it to shape very easily and lasts for years. 1953 80"
1987 mini city e 2011 90" |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
Or maybe neoprene. Pretty cheap on eBay and available in different colours. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
I did the edges of the seatbox lids, floor panels, transmission tunnel etc with a roll of 5mm thick closed cell foam approx 15mm wide. It's held up really well and a 10m roll is only a few pounds from ebay.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20922 ![]() ![]() |
I've got some of that above from eBay trouble is the adhesive is rubbish, if it gets warm it'd move about.
I guess though it was very cheap so I won't complain. |
Thanks a lot chaps
I like the idea of the neoprene so I'll see how that turns out Defender 90 XS TD5 (03 Reg) |
