![]() | Home > In Car Electronics > CB SWR readings |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Fixed roof mount is the way to go Andy
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
^^^I was hoping that the super ground plane provided by the roll cage would be enough. I've scraped the paint off the roll cage so there is direct metal-to-metal contact between the mount and cage. The cage is multiple located to the chassis/roof/rear tub etc
cheers simon |
To conclude this, I got a new aerial, mount and cable/connectors and I now have a 1.3 SWR reading across all channels.
Very pleased, not sure which of the above made the biggest difference but glad it did. Cheers Simon |
pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273 ![]() ![]() ![]() |
It might be worth considering a artificial ground plane, made a big difference on my set up.
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Have you an Earth from the Antenna Mount to the Chassis? Might make a big difference. NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
As I said above, all is great now...
![]() Cheers Simon |
