Home > In Car Electronics > CB SWR readings
Page 2 of 2 <12
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Censored , having fabricated the new mount I did a SWR reading today.....just the same as before. Cant get much better than about 4.
I plugged in my handheld CB just to see if the CB unit itself as causing problems, but similar readings.
I've got some new cable on order and I think I'll order a new aerial & mount.
After that, I'll need to swap the truck.. Rolling Eyes
cheers
simon
Post #351028 11th Aug 2014 4:42pm
CFB
Fixed roof mount is the way to go Andy
Post #351031 11th Aug 2014 5:13pm
couplands
^^^I was hoping that the super ground plane provided by the roll cage would be enough. I've scraped the paint off the roll cage so there is direct metal-to-metal contact between the mount and cage. The cage is multiple located to the chassis/roof/rear tub etc
cheers
simon
Post #351035 11th Aug 2014 5:19pm
couplands
To conclude this, I got a new aerial, mount and cable/connectors and I now have a 1.3 SWR reading across all channels.
Very pleased, not sure which of the above made the biggest difference but glad it did.
Simon
Post #351433 13th Aug 2014 6:50pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
It might be worth considering a artificial ground plane, made a big difference on my set up.
Post #352438 18th Aug 2014 11:39pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Have you an Earth from the Antenna Mount to the Chassis? Might make a big difference. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #352559 19th Aug 2014 6:29pm
couplands
As I said above, all is great now...Smile
Simon
Post #352565 19th Aug 2014 6:55pm
Page 2 of 2 <12
