Home > Maintenance & Modifications > TD5 FUEL FILTER WIRING
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
QUESTION: I have a 300tdi 110, I want to fit the fuel sedimenter filter that bolts to the chassis in the rear wheel arch. I also have a TD5 instrument panel that I want to fit soon. Will it be possible to use the fuel water warning light on the dash for the sensor and plug that can screw on to the bottom of the filter? 1998 110 300Tdi White Hard Top
Post #349047 2nd Aug 2014 7:02pm
Interlet
BUMP
Someone must know the answer to this 1998 110 300Tdi White Hard Top
Post #349164 3rd Aug 2014 10:16am
Retroanaconda
Have a look through the wiring diagrams/info in RAVE. I think it should be possible, it may even just be a case of running the necessary wires from the sensor to the warning light.
Post #349165 3rd Aug 2014 10:18am
Lou Sparts
My Td5 does,nt have a water in fuel light or any wiring to the filter ! 2005 Td5 90 XS
Steve
Post #349176 3rd Aug 2014 10:51am
Interlet
Interesting. They should all have it, AFAIK. Some people don't bother with it though, and replace the black wired plug for a blank white one... 1998 110 300Tdi White Hard Top
Post #349184 3rd Aug 2014 11:27am
Interlet
Also, does anyone know how the filter actually bolts to the chassis? One bolt is clearly easy, as access to behind the hole is outside of the chassis, but the front most hole is literally inside the chassis - how do you get a bolt on the back of that? 1998 110 300Tdi White Hard Top
Post #349193 3rd Aug 2014 11:59am
