![]() | Home > In Car Electronics > Removing battery - need to resync fob? |
what fob you got , the black square ish one with 2 rubber buttons ?
normally reconnect battery then push fob button few times (maybe 5 or 6 ) until it works and job done you don't need to take it to garage as you would have to just for flat battery or just fitting new battery im pretty sure you should get a eka code other wise you stuck if fob packs up , but eka code is not for resycning fobs anyway and eka code is done on the ign switch not on the door |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
All vehicles fitted with a Lucas 10AS unit have an EKA code. For some reason many dealers appear to be clueless and deny this for recent models (maybe because a note of what it is is no longer sent to the dealer with the vehicle).
It takes a few seconds with a compatible diagnostic system to read the code, which is actually one of the infamous security vulnerabilities of the Defender. You shouldn't however need the code to change the vehicle battery. |
Riyo Member Since: 26 Jun 2014 Location: Aberdeen Posts: 89 ![]() ![]() ![]() |
yep its the black square one with 2 buttons,
ok thats good to know the fob will resync by just pressing a few times. I was confused because the manual states "the effect of disconnecting the battery can cause the vehicle systems to reset automatically and the key fob needs to be resynchronised as per key fob battery replacement procedure" In this battery fob replacement procedure it says that the battery must be changed within 5 minutes or the EKA needs to be entered to resynchronise with the fob. I did find in the service hanbook 2 numbers though - Key Number X99999 and Emergency Key Access Code XXX999999 X-character, 9-Number Doesnt really equate to the proper EKA format...ive read some of the other posts on here regarding EKA and it seems to be a very ambiguous topic |
ive never heard of this , maybe a new thing ! eka is normally 4 numbers , maybe another new thing ! |
yep that's what I thought |
maybe it means the fob battery cannot be out for more than 5 minutes or you need the EKA... but the landy battery can be out for however long.
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
No problem with changing fob batteries either.....one of my fobs has been through the washing machine, stopped working been dried out, still not working, new battery and happy days all well again. This was a while ago but no entering of the code was required nor a trip to a dealer.
