![]() | Home > Puma (Tdci) > Sticky Ignition unit |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5943 ![]() ![]() |
Mine is similar. Some times key stuck in, can't get it out, can't turn it
![]() ![]() Andy |
Is it linked to this?
http://www.defender2.net/forum/topic29850.html |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Hi Andy
No i don't think it is, it doesn't stick as such, it just won't turn to position 1, and when switching the engine off, it won't go to position 0/off very easily either, it 'feels' like the barrel and latches are not working correctly, or the steering lock is interfering with it. JD 2008 TDCi 2.4 XS CSW |
I have had similar issues on mine and just put it down to poor tolerances in the sum of the parts. It happens less now but is a pain when it does happen as it can take a minute or more of wiggling to resolve.
What you two are describing is like mine, but that thread got me worried about if it gets worse to a point when it sticks in the on position. Got a xeng barrel lock to fit but have been to worried for months.
Is it a big job to change the barrel ?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17816 ![]() ![]() ![]() |
It's not easy to change the barrel since the lock assembly is secured to the column by shear-bolts. It is time-consuming.
New lock assemblies are not especially expensive however (though I am not sure about current main dealer prices). I bought a set consisting of a new stearing column lock assembly (c/w 'ignition'/starter switch) and a driver's door lock assembly when I found that my driver's door lock had siezed, but in the end managed to un-sieze the lock. It was a genuine part from Ebay and was under £50. I bought the pair so that I still only needed one key. |
I had a feeling it wouldn't be easy
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 707 ![]() ![]() ![]() |
I'm going to have to do mine. It's starting to worry me that it might just stop working altogether.
Someone said that it's a top part of the dash out job .. Is that right? 2008 Defender 110 XS SW - M57N2 / 8HP70X |
Might have to get mine into dealer. I hate the ideas of others fiddling.
Andy |
Wish I hadn't said that .. It's stopped working altogether and somehow I have to get to work on Monday.
I tried some WD40 and it made it even worse. I was all prepared to take it out and had the dash apart and then took the advice of mk1collector (thanks) and got some graphite powder .. It's usable again,
![]() Got the graphite lock lubricant from Maplin .. I would give it a go before going to the hassle of changing it. 2008 Defender 110 XS SW - M57N2 / 8HP70X |
Hmmm i wonder if toolstation might sell it, is it a spray ?
Yeah .. Tiny can .. http://www.maplin.co.uk/p/ambersil-graphite-lock-lubricant-n68jb 2008 Defender 110 XS SW - M57N2 / 8HP70X
