Home > Puma (Tdci) > Sticky Ignition unit
johnnyd
Hi All
I am having a bit of trouble with my ignition key and getting it to turn on first insertion, its happened twice now, and i have really struggled to start the truck, i 'wiggle' the steering lock and it doesn't make a great deal of difference, its both keys, so not a key issue i think. Is there anything i can do, i don't think its a lubrication issue either, i think its mechanical..
I dread to think how much a replacement firing of an ignition key setup is ?
Thanks
JD 2008 TDCi 2.4 XS CSW
Post #344409 11th Jul 2014 7:26am
landy andy
Mine is similar. Some times key stuck in, can't get it out, can't turn it Big Cry Big Cry
Andy
Post #344415 11th Jul 2014 8:09am
landy andy
Post #344416 11th Jul 2014 8:13am
johnnyd
Hi Andy
No i don't think it is, it doesn't stick as such, it just won't turn to position 1, and when switching the engine off, it won't go to position 0/off very easily either, it 'feels' like the barrel and latches are not working correctly, or the steering lock is interfering with it.
Post #344418 11th Jul 2014 8:17am
I have had similar issues on mine and just put it down to poor tolerances in the sum of the parts. It happens less now but is a pain when it does happen as it can take a minute or more of wiggling to resolve.
Post #344430 11th Jul 2014 9:20am
landy andy
What you two are describing is like mine, but that thread got me worried about if it gets worse to a point when it sticks in the on position. Got a xeng barrel lock to fit but have been to worried for months.
Post #344433 11th Jul 2014 9:37am
johnnyd
Is it a big job to change the barrel ?
Post #344437 11th Jul 2014 9:51am
It's not easy to change the barrel since the lock assembly is secured to the column by shear-bolts. It is time-consuming.
New lock assemblies are not especially expensive however (though I am not sure about current main dealer prices).
I bought a set consisting of a new stearing column lock assembly (c/w 'ignition'/starter switch) and a driver's door lock assembly when I found that my driver's door lock had siezed, but in the end managed to un-sieze the lock. It was a genuine part from Ebay and was under £50. I bought the pair so that I still only needed one key.
Post #344452 11th Jul 2014 10:34am
johnnyd
I had a feeling it wouldn't be easy Wink
Big Cry 2008 TDCi 2.4 XS CSW
Post #344462 11th Jul 2014 10:55am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
I'm going to have to do mine. It's starting to worry me that it might just stop working altogether.
Someone said that it's a top part of the dash out job .. Is that right? 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #344618 12th Jul 2014 12:14am
landy andy
Might have to get mine into dealer. I hate the ideas of others fiddling.
Andy
Post #344634 12th Jul 2014 6:44am
carrotbay
Wish I hadn't said that .. It's stopped working altogether and somehow I have to get to work on Monday. Crying or Very sad 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #344732 12th Jul 2014 6:41pm
carrotbay
I tried some WD40 and it made it even worse. I was all prepared to take it out and had the dash apart and then took the advice of mk1collector (thanks) and got some graphite powder .. It's usable again, Very Happy
Got the graphite lock lubricant from Maplin .. I would give it a go before going to the hassle of changing it. 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #344908 13th Jul 2014 5:05pm
johnnyd
Hmmm i wonder if toolstation might sell it, is it a spray ?
Post #344918 13th Jul 2014 5:29pm
carrotbay
Yeah .. Tiny can .. http://www.maplin.co.uk/p/ambersil-graphite-lock-lubricant-n68jb 2008 Defender 110 XS SW - M57N2 / 8HP70X
Post #344926 13th Jul 2014 5:39pm
