Home > Technical > why not make them the same?
Caterham
Why would they only put what appears to be a cover on just one of the two transfer box mounts?
Post #344119 9th Jul 2014 9:46pm
munch90
one been left off ?
by the marks on the bolts I guess gearbox or transfer box has been out before
Post #344126 9th Jul 2014 9:57pm
Caterham
Aha. Maybe....gbox has been replaced but didn't think the tbox had been out.....does it need to come out to get the gbox out?
Post #344129 9th Jul 2014 10:01pm
munch90
yes you can remove whole box in one or remove transfer first then main box , but what ever way those mountings have to come off
Post #344131 9th Jul 2014 10:04pm
Caterham
Bearing in mind the extent of my off adventures I don't think a missing cover is going to make me loose any sleep but all the same I presume their should be a shield on both?
Thumbs Up
Thanks
Post #344136 9th Jul 2014 10:27pm
Heat shield due to the proximity of the exhaust to one mount only.
Post #344139 9th Jul 2014 10:36pm
Caterham
blackwolf - I presume that is simply a guess?
if I remember neither are very close to the exhaust and the one with the shield is furthest away. so assuming it isn't a sheat shield what are they / is it for - to help prevent mechanical damage to the rubber from impact?
Post #344171 10th Jul 2014 7:02am
Not so much a guess as the only explanantion I could come up with when I was wondering the same thing when I changed my clutch recently. Evidently on the TDCi there is some reason why the n/s mounting needs protection, they are all like that (n/s only). The ex-2013-2.2-write-off gearbox/transferbox assembly I bought, which came with the mountings still on, also had a shield on the n/s mount only, so there must be a reason.
Exhaust and heat was the only plausing explanation I could come up with.
If you want yours to match you're welcome to the surplus shield I have!
Post #344177 10th Jul 2014 7:57am
Caterham
thanks Blackwolf but I'm happy as is all the same.
I have to agree it does look like a heat shield but seems odd as I'd have thought the other mount would have been more susceptible to heat (from memory).?
the n/s with the shield is lower and hence I wondered as flimsy as it is whether it might be there to protect against impact?
oh well perhaps another little quirk?
Post #344179 10th Jul 2014 8:04am
Td5 is the same, it's an exhaust heat shield.
There's one on the LH engine mounting rubber too.
Post #344180 10th Jul 2014 8:12am
grafty99
can confirm my Td5 only has one Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #344182 10th Jul 2014 8:14am
Caterham
super - thanks guys.
- and breath out.
Very Happy
Post #344185 10th Jul 2014 8:35am
