![]() | Home > Technical > why not make them the same? |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
Why would they only put what appears to be a cover on just one of the two transfer box mounts?
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
one been left off ?
by the marks on the bolts I guess gearbox or transfer box has been out before |
Aha. Maybe....gbox has been replaced but didn't think the tbox had been out.....does it need to come out to get the gbox out?
Bearing in mind the extent of my off adventures I don't think a missing cover is going to make me loose any sleep but all the same I presume their should be a shield on both?
Thanks |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18051
Heat shield due to the proximity of the exhaust to one mount only.
blackwolf - I presume that is simply a guess?
if I remember neither are very close to the exhaust and the one with the shield is furthest away. so assuming it isn't a sheat shield what are they / is it for - to help prevent mechanical damage to the rubber from impact? |
Not so much a guess as the only explanantion I could come up with when I was wondering the same thing when I changed my clutch recently. Evidently on the TDCi there is some reason why the n/s mounting needs protection, they are all like that (n/s only). The ex-2013-2.2-write-off gearbox/transferbox assembly I bought, which came with the mountings still on, also had a shield on the n/s mount only, so there must be a reason.
Exhaust and heat was the only plausing explanation I could come up with. If you want yours to match you're welcome to the surplus shield I have! |
thanks Blackwolf but I'm happy as is all the same.
I have to agree it does look like a heat shield but seems odd as I'd have thought the other mount would have been more susceptible to heat (from memory).? the n/s with the shield is lower and hence I wondered as flimsy as it is whether it might be there to protect against impact? oh well perhaps another little quirk? Last edited by Caterham on 10th Jul 2014 7:35am. Edited 1 time in total |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Td5 is the same, it's an exhaust heat shield.
There's one on the LH engine mounting rubber too. |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
can confirm my Td5 only has one
super - thanks guys.
- and breath out. |
| All times are GMT |
