![]() | Home > Puma (Tdci) > Smoking Problem - Engine White Smoke |
| adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389
afternoon fella, drop down we'll have a look at it....see linky below, A STONE THROW away... Putting Dreams on Drives at JLR Solihull..
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
When was fuel filter changed last?
Andy |
| clifflandy Member Since: 13 Mar 2014 Location: Lichfield Posts: 110
Thanks Adafish - can I drop by on Friday for you to take a look please?
Fuel filter was replaced 2 months ago. |
| fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126
This reminds me of valve stem seals - from my old mini 1000 days...but better check with the professionals..
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Valve stem seals usually means you burn oil on just start up or continuously dependant on how bad they are, had an old BMW that did this on pot 5 just on start only, advice was to leave well alone at the time. If you go through life with your head in the sand....all people will see is an ar5e!!
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
Burning lubricating oil usually = blue smoke. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677
White smoke is either unburnt fuel or water. Head gasket? Cracked/warped head?
