![]() | Home > Puma (Tdci) > Smoking Problem - Engine White Smoke |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389 ![]() ![]() ![]() |
afternoon fella, drop down we'll have a look at it....see linky below, A STONE THROW away... Putting Dreams on Drives at JLR Solihull..
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
When was fuel filter changed last?
Andy |
clifflandy Member Since: 13 Mar 2014 Location: Lichfield Posts: 110 ![]() ![]() ![]() |
Thanks Adafish - can I drop by on Friday for you to take a look please?
Fuel filter was replaced 2 months ago. |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
This reminds me of valve stem seals - from my old mini 1000 days...but better check with the professionals..
Valve stem seals usually means you burn oil on just start up or continuously dependant on how bad they are, had an old BMW that did this on pot 5 just on start only, advice was to leave well alone at the time. If you go through life with your head in the sand....all people will see is an ar5e!!
Burning lubricating oil usually = blue smoke. Steve.
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
White smoke is either unburnt fuel or water. Head gasket? Cracked/warped head?
