![]() | Home > Maintenance & Modifications > Towing electrics cable loom |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17885 ![]() ![]() ![]() |
Yes, they are provided to allow the subsequent fitment of a 12S socket without modifying any harnesses. For a 12N you don't need to do anything with them.
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Where did you get this loom from.
Looking for one for my 90 at a decent price Defender 90 XS TD5 (03 Reg) |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 ![]() ![]() ![]() |
Thanks Blackwolf
I am still a little confused as I have just googled pin outs for 12S and can't see where they use those colours of wire. Am I missing something ? Cheers Gavin |
Hi Waldo
I got it from Island 4x4. Seems good quality and well put together. http://www.island-4x4.co.uk/electrics-ntyp...-7340.html Base price, which is also marked as a web special is £29.99 - but add delivery (£5) and VAT brings you to £41.99. Though if you are buying a few things delivery is free if you spend over £50 Cheers Gavin |
Thanks a lot mate
Will Defender 90 XS TD5 (03 Reg) |
the wire maybe a reverse light feed to the 12s socket as the 12n doesn't have reverse light terminal |
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 ![]() ![]() ![]() |
Does that mean from this point you can wire up a 12S socket as well, without having to take wire beyond this loom? I didn't think there was a permanent live direct-to-battery connection in there? Think I've missed the point. 2009 110 XS Station Wagon |
I'm sure that somewhere on this forum there's a link to the installation instructions for the 12S (which I don't have to hand), but I am sure that there is a hook-up to the additional external connectors on the 12N part you have, I think for a non-switched live and the reversing light.
The 12S genuine kit is much more involved to fit than the 12N since it entails running an ingition-switched supply from the battery box and includes fitting an ignition-controlled relay wired from a feed in the dash, as well as the connections to the back end. If you can find the instruction sheet all will become clear. The fitting instructions for the 12S socket are available free and without registering if you visit Landrover's TOPIX website at www.landrovertechinfo.com |
How's your socket holding up?
Mine arrived today and I was surprised to see it's Britpart OEM. I know OEM should be better than Britparts standard stuff but I tend to steer clear of them. Defender 90 XS TD5 (03 Reg) |
