Home > Technical > Alloy wheel question
spudfan
Ireland
Is it possible to spray (successfully Mr. Green ) alloy wheels? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #337298 10th Jun 2014 7:21pm
jimbob7
Need etch primer if it's bare alloy,otherwise treat as normal, clean, key the paint, away you go.Powder coat is better/tougher. Pov.spec,ftw. 2006, 110,TD5.
Post #337309 10th Jun 2014 7:39pm
spudfan
Ireland
O.K. Thumbs Up Just thinking of white Land Rover boost alloys Whistle 1982 88" 2.25 diesel
Post #337312 10th Jun 2014 7:44pm
jimbob7
Thort the same thing my self funnily enough,bit too much white on this'un tho, imo.
Post #337317 10th Jun 2014 7:54pm
GUM97
Yep,mo sprayed some Deep-Dish Defender alloys a while back Thumbs Up An engine to TDi for!
Post #337330 10th Jun 2014 8:28pm
SailingTom
Had these sprayed. The key is in the prep, but its much better than powdercoating. Thumbs Up
 Defender puma dormobile camper
Post #337387 11th Jun 2014 5:50am
spudfan
Ireland
Two fine looking Land Rovers Thumbs Up Wonder how much prep work it would take to get the wife to look that good. Probably need a panel beater on the team Laughing 1982 88" 2.25 diesel
Post #337407 11th Jun 2014 8:39am
You'll get a better gloss with the paint, as mentioned prep is important.
With the paint at least if you get damage you can re-spray.
Be careful of runs though on an un-even surface, thin even coats would be best.
Post #337427 11th Jun 2014 9:15am
spudfan
Ireland
I'd really like to get Boost Alloys done white. Can the tyre fitter fit the tyres without blemishing the paintwork?
Thanks for the comments and photos Thumbs Up 1982 88" 2.25 diesel
Post #337435 11th Jun 2014 9:58am
spudfan
Ireland
Was just checking out the photos on this thread and the wife happened to spot the above post. Damnit, looks as though my account on this site was "hacked" and the above post was placed by some cyper hacker. Must tell Martin to up the security on this site. Well that's what I told the Mrs anyway. Whistle 1982 88" 2.25 diesel
Post #337450 11th Jun 2014 10:37am
K9F
Yes tyres can be fitted without damaging the paint as long as it's a half-decent paint and not chocolate.. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #337452 11th Jun 2014 10:38am
spudfan
Ireland
Will have a word with the local tyre fitters just to make sure he can do a good job. 1982 88" 2.25 diesel
Post #337456 11th Jun 2014 10:42am
