![]() | Home > Technical > Alloy wheel question |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Is it possible to spray (successfully
O.K.
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Thort the same thing my self funnily enough,bit too much white on this'un tho, imo.
Pov.spec,ftw. 2006, 110,TD5. |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Yep,mo sprayed some Deep-Dish Defender alloys a while back
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
| SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733
Had these sprayed. The key is in the prep, but its much better than powdercoating.
Click image to enlarge Defender puma dormobile camper |
Two fine looking Land Rovers
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
You'll get a better gloss with the paint, as mentioned prep is important.
With the paint at least if you get damage you can re-spray. Be careful of runs though on an un-even surface, thin even coats would be best. |
I'd really like to get Boost Alloys done white. Can the tyre fitter fit the tyres without blemishing the paintwork?
Thanks for the comments and photos 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Was just checking out the photos on this thread and the wife happened to spot the above post. Damnit, looks as though my account on this site was "hacked" and the above post was placed by some cyper hacker. Must tell Martin to up the security on this site. Well that's what I told the Mrs anyway. 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Yes tyres can be fitted without damaging the paint as long as it's a half-decent paint and not chocolate..
Will have a word with the local tyre fitters just to make sure he can do a good job. 1982 88" 2.25 diesel
| All times are GMT |
