![]() | Home > Puma (Tdci) > External Power Supply Point ? |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Hello,
I saws picture of a Defender with the external vents cover removed instead of a power supply point, something that is a neat looking thing where I can use it to pump air after deflating tyres ? I cannot find the thing I want, I recall seeing something at a website. 2016 Defender 90 Adventure Edition |
Forum Search Reveals:
http://nakatanenga-tours.de/shop/article_G...926A-OB%26 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Is this what you are after? Made by GMB, Germany and can be bought from amongst others MUD.
GMB make some excellent stuff with quality to match. http://www.gmb-mount.de/shop.htm and search for MB-D926A under Defender, or http://www.mudstuff.co.uk/gmb-fender-locker.html |
Thank you, how difficult would it be to install 2016 Defender 90 Adventure Edition
I ordered the one with the air supply and gauge to inflate the tyres 2016 Defender 90 Adventure Edition
I have it installed! nice piece of kit! well done Skyfall. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Thank you Daniell,
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
I think an Anderson plug on the seat base would be an easier and weather free place to sight one
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
