Home > Puma (Tdci) > External Power Supply Point ?
SkyFallSilver
Kuwait
Hello,
I saws picture of a Defender with the external vents cover removed instead of a power supply point, something that is a neat looking thing where I can use it to pump air after deflating tyres ?
I cannot find the thing I want, I recall seeing something at a website. 2016 Defender 90 Adventure Edition
Post #337201 10th Jun 2014 1:06pm
K9F
Forum Search Reveals:
http://nakatanenga-tours.de/shop/article_G...926A-OB%26 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #337210 10th Jun 2014 1:29pm
smb
Is this what you are after? Made by GMB, Germany and can be bought from amongst others MUD.
GMB make some excellent stuff with quality to match.
http://www.gmb-mount.de/shop.htm and search for MB-D926A under Defender, or
http://www.mudstuff.co.uk/gmb-fender-locker.html
Post #337217 10th Jun 2014 1:41pm
SkyFallSilver
Kuwait
Thank you, how difficult would it be to install 2016 Defender 90 Adventure Edition
Post #337229 10th Jun 2014 2:51pm
smb
It's very straightforward. As easy as installing a snow cowl. It depends what you want to put in it that will be the deciding factor. It is a lot easier if you take the drivers side wheel and wheel arch liner off although not a necessity.
Post #337236 10th Jun 2014 3:12pm
SkyFallSilver
Kuwait
I ordered the one with the air supply and gauge to inflate the tyres 2016 Defender 90 Adventure Edition
Post #337249 10th Jun 2014 4:36pm
dgardel
Italy
I have it installed! nice piece of kit! well done Skyfall. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #337296 10th Jun 2014 8:19pm
SkyFallSilver
Kuwait
Thank you Daniell, Smile 2016 Defender 90 Adventure Edition
Post #337321 10th Jun 2014 9:00pm
bear100
I think an Anderson plug on the seat base would be an easier and weather free place to sight one Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #337329 10th Jun 2014 9:23pm
