![]() | Home > Maintenance & Modifications > Door Seals - LR or Cheapy? |
I put cheap seals on and they make the doors much harder to shut so I'm putting genuine on soon to hopefully get rid of the annoyance of having to slam the doors three times to get them to shut
^^I found the same. Genuine is the way! An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
Genuine!
Cheap seals can work for a while, but I just dont think they can beat the Genuine item! |
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 ![]() ![]() |
i shopped around and got the genuine seals for about £40 each, and they fit the best by far
rtm89 Member Since: 14 May 2013 Location: North Yorkshire Posts: 260 ![]() ![]() ![]() |
We used to replace door seals all the time on Defenders and buy cheap buy twice was definitely true.
They all seemed to be a horrid fit and if you could get them on they either dropped off or leaked after a short while. I would always stick with genuine on these. Our mechanics refused to fit anything else in the end. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Genuine, not cheap but worth it.
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2025 ![]() ![]() ![]() |
I've heard good things about the nakatanenga ones!
Any joy with these Brendan ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 631 ![]() ![]() ![]() |
Go genuine, I started with Britpart (Paddocks) and soon replaced them as they didn't fit and leaked...
Raddy Member Since: 20 Aug 2013 Location: St. Sampsons Posts: 55 ![]() ![]() ![]() |
Cheers for the advice, think I'll stump up for the genuine parts in that case!
