Home > Maintenance & Modifications > Door Seals - LR or Cheapy?
Raddy
Guernsey 2007 Defender 90 Puma 2.4 CSW Rimini Red
Is it worth spending the seemingly ridiculous amount for LR front door seals or are the cheaper aftermarket type ones much the same? Thought id get some opinions before jumping in.
Forever having problems with the passenger door catching on the seal when shutting/opening and yanking it off the frame and the top falling but this maybe the fault of the door i suppose.
Post #337087 9th Jun 2014 10:07pm
mk1collector
I put cheap seals on and they make the doors much harder to shut so I'm putting genuine on soon to hopefully get rid of the annoyance of having to slam the doors three times to get them to shut Big Cry
Post #337090 9th Jun 2014 10:11pm
GUM97
^^I found the same. Genuine is the way! An engine to TDi for!
Post #337134 10th Jun 2014 8:06am
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Genuine!
Cheap seals can work for a while, but I just dont think they can beat the Genuine item!
Post #337139 10th Jun 2014 8:12am
Fullfat
1999 Defender 90 Td5 HT Rioja Red
i shopped around and got the genuine seals for about £40 each, and they fit the best by far
Post #337171 10th Jun 2014 10:17am
rtm89
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
We used to replace door seals all the time on Defenders and buy cheap buy twice was definitely true.
They all seemed to be a horrid fit and if you could get them on they either dropped off or leaked after a short while.
I would always stick with genuine on these. Our mechanics refused to fit anything else in the end.
Post #337173 10th Jun 2014 10:38am
Genuine, not cheap but worth it.
Post #337178 10th Jun 2014 10:58am
bear100
I've heard good things about the nakatanenga ones!
Any joy with these Brendan Razz 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #337184 10th Jun 2014 11:11am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
Go genuine, I started with Britpart (Paddocks) and soon replaced them as they didn't fit and leaked...
Post #337211 10th Jun 2014 12:30pm
Raddy
Cheers for the advice, think I'll stump up for the genuine parts in that case!
Post #338284 15th Jun 2014 5:33pm
