![]() | Home > Td5 > noisy fuel pump |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Could be sucking air in through the FPR or injector seals and washers
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
If it is the puma, as you know it's submerged in the tank. Quite a few td5'ers have cut an access panel in the boot floor saves dropping the tank
| dancerdave Member Since: 14 Mar 2014 Location: N Ireland Posts: 80
I'm hoping it's injector seals as that would be much cheaper. Is there any guides to show how it's done?
| SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455
Unlikely to be injector seals IMHO - but they are easy enough to do if you need to.
I had this problem on a previous vehicle - I changed the fuel pump at considerable expense but the issue remained. I then changed the fuel filter and it was sorted. Lesson - change the cheap and easy stuff first, even if they are not the most probable cause! My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
Apart from the noise am I going to cause any more damage by continuing to drive until I get it fixed. Engine seems to be running fine.
| Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897
It's perfectly OK to drive with a noisy pump.
Won't do any harm and is unlikely to breakdown. If it is injector seals they will be prone to breakdowns. ![]() |
Thanks. I'll try the injector seals and fuel filter first and let you know how I get on.
it was the fuel filter
