Home > Wheels & Tyres > Feels a bit hard with pressures I have - advice?
pob1968
Hi I am running 36 psi at the front and 40 psi at the rear on my 110 hard top, I do have to carry maximum weight about once a week but I find that the ride is a bit hard. I would like it to be a bit softer, what pressure would you recommend guys?
I have steel modulars with Cooper Discoverer STT (265/75/16) tyres 110 Hardtop
Post #336160 6th Jun 2014 12:04pm
32front 38 rear for me but that is on a 90.
I don't tow either, not heavy towing anyway. I've ways ran this pressure as is in the handbook.
I don't doubt a 110 may be a touch more though.
Post #336174 6th Jun 2014 1:31pm
ARC99
When running at max weight or towing I use 30 psi on the front and 65 psi on the rear as per the book.
For normaul use I use 30 psi front and 38 in the rear.
That's running 235/85/16 Don't make old people mad.
Richard
Post #336179 6th Jun 2014 1:49pm
235/85R16 For me too.
Post #336180 6th Jun 2014 2:01pm
Grouse
Same tyres as you Pob and I am running 28/35 unladen / part laden. on max load and I mean max load when she is almost to the bump stops she is 28/48 on Std H/D suspension - works 100% fine, even wear and no odd handling
Post #336226 6th Jun 2014 7:50pm
pob1968
Thanks, looks like when I'm running round empty the pressures are a bit high making it a hard ride then Smile
Will drop them and see Embarassed 110 Hardtop
Post #336316 7th Jun 2014 8:14am
