![]() | Home > Wheels & Tyres > Feels a bit hard with pressures I have - advice? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21020 ![]() ![]() |
32front 38 rear for me but that is on a 90.
I don't tow either, not heavy towing anyway. I've ways ran this pressure as is in the handbook. I don't doubt a 110 may be a touch more though. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
When running at max weight or towing I use 30 psi on the front and 65 psi on the rear as per the book.
For normaul use I use 30 psi front and 38 in the rear. That's running 235/85/16 Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
235/85R16 For me too.
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 537 ![]() |
Same tyres as you Pob and I am running 28/35 unladen / part laden. on max load and I mean max load when she is almost to the bump stops she is 28/48 on Std H/D suspension - works 100% fine, even wear and no odd handling
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 ![]() |
Thanks, looks like when I'm running round empty the pressures are a bit high making it a hard ride then
![]() Will drop them and see ![]() |
