Home > Technical > Svx lights -Relay not working with trailer dash indicator
GEllis
England 2013 Defender 110 Puma 2.2 USW Indus Silver
Fitted Svx Led lights today and replaced the relay, all working great. Then took out a trailer and the dash light that usually flashes when the trailer lights are plugged in does not operate?
Any one had a similar issue.
Post #335140 1st Jun 2014 10:57pm
munch90
the dash light won't work with led flasher unit , you need the adjustable flasher unit , search Rdx flasher unit or Rdx relay on forum lots about it
Post #335144 1st Jun 2014 11:07pm
leeds
Which make of LED lights and flasher unit did you use?
Some trailers/caravans have filament bulbs fitted, some have LED, therefore the resistance load/current draw can vary a lot.
Talking to the technical guys who supplied the SVX lights to Land Rover he clearly stated that many of the aftermarket systems available would not function properly and legally with a trailer fitted.
They supply what they call an Intelligent Power Loading Systems with their aftermarket LED systems.
Maybe it is a case of asking your supplier for a solution?
Brendan
Post #335145 1st Jun 2014 11:17pm
The RDX relay will be your only option. I have one - does what it says on the tin.
Thumbs Up
Post #335146 1st Jun 2014 11:30pm
Oscar Romeo
Location: South Yorks, the pinnacle of all human achievement
England 2010 Defender 110 Puma 2.4 XS CSW Rimini Red
+ 1 Thumbs Up
5 min job!
Post #335329 2nd Jun 2014 9:56pm
Myers
United Kingdom 2013 Defender 90 Puma 2.2 HT Epsom Green
Yep, RDX relay will sort your problems. I have LEDs on the vehicle and have towed various trailers with normal lamps, works every time Myers - Somewhere on Salisbury Plain
Puma 90 Hardtop (XS Spec)
Post #335385 3rd Jun 2014 8:53am
