![]() | Home > Puma (Tdci) > back diff as spare for front D-90 non ABS |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6210 ![]() ![]() ![]() |
On a D90 the back and front are the same.
Keep it as a spare! You may even have been lucky... was the back diff a 4 pinion HD one? this will give you a HD front axle then! |
pdv Member Since: 07 Feb 2014 Location: Asse Posts: 27 ![]() ![]() ![]() |
no it's 2pin i will look at it again to be sure. i know the 110 is 4pin of P38 and ABS models normally
but is it plug and play or does take more fit it in the front ? |
90 rear is straight fit into 90/110/130 front.
