Home > Puma (Tdci) > back diff as spare for front D-90 non ABS
pdv
Belgium 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Recently I changed the back diff to an ashcroft locker and the standard diff just has 60 000 KM, so it's in good condition. My question is if it is possible to use the back diff as spare for the front in case I brake it ? or will i need extra parts in case off brake ?
grtz
Tarcis
Post #334787 31st May 2014 2:31pm
On a D90 the back and front are the same.
Keep it as a spare!
You may even have been lucky... was the back diff a 4 pinion HD one? this will give you a HD front axle then!
Post #334813 31st May 2014 5:29pm
pdv
no it's 2pin i will look at it again to be sure. i know the 110 is 4pin of P38 and ABS models normally
but is it plug and play or does take more fit it in the front ?
Post #334821 31st May 2014 6:10pm
90 rear is straight fit into 90/110/130 front.
Post #335016 1st Jun 2014 5:40pm
