Home > Puma (Tdci) > Bottom door seal oddity!
gilarion
Bottom door seal!
Today I noticed that the bottom door seals on the drivers and passenger doors are different, I mean they are the same seal, but one has the lip facing outwards and the other has the lip facing inwards, to me it looks as though one has been fitted wrong, but not sure which is the right or wrong way!
Has anybody got a picture of how the bottom door seals should be fitted.
I have had the Land Rover for two years and I have never noticed this until now, but I am sure they should both be fitted the same way round.
As the seals are riveted to the bottom of the door Conwy Land Rovers can sort it out if there is a problem, but I do not want to go back with the vehicle (a round trip of some sixty miles) if the seals are supposed to be fitted this way!
Post #331814 18th May 2014 6:29pm
ericvv
Post #331818 18th May 2014 6:39pm
gilarion
No they do not look like those seals my defender is 2010 year.
Do you know if those seals can be retro fitted they look so much better than the ones i have fitted.
Post #331821 18th May 2014 6:42pm
ericvv
Post #331824 18th May 2014 6:46pm
gilarion
Thanks. Read all the pages so might go down that route, however, in the mean time I still want my 'older type seals put right if indeed they are wrong!
Post #331831 18th May 2014 7:13pm
gilarion
As I had to travel to Manchester this morning and had to drive down the A55 which meannt almost passing the main dealership I decided to pop in, and yes the drivers door bottom seal has been fitted the wrong way. The dealership have agreed to put it right and also because the seal has been letting in water and soiled the front carpet they have agreed to replace that as well.
Must have been a late Friday afternoon at the factory when someone fitted the seal the wrong way up that or they should have gone to Specsavers Laughing
Post #332099 19th May 2014 7:08pm
