![]() | Home > Puma (Tdci) > Bottom door seal oddity! |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Not sure what model year you have, but as of model year 2011 a new type door seal was fitted. Pictures of how these should be fitted are in below thread from dgardel. Eric
http://www.defender2.net/forum/topic6370.h...door+seals You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
No they do not look like those seals my defender is 2010 year.
Do you know if those seals can be retro fitted they look so much better than the ones i have fitted. |
So you have the older type. For retrofitting the new type, keep reading dgardel thread, somewhere in the 7 pages you find all you need to know.
![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks. Read all the pages so might go down that route, however, in the mean time I still want my 'older type seals put right if indeed they are wrong!
As I had to travel to Manchester this morning and had to drive down the A55 which meannt almost passing the main dealership I decided to pop in, and yes the drivers door bottom seal has been fitted the wrong way. The dealership have agreed to put it right and also because the seal has been letting in water and soiled the front carpet they have agreed to replace that as well.
Must have been a late Friday afternoon at the factory when someone fitted the seal the wrong way up that or they should have gone to Specsavers ![]() |
